Can't get 'em??
Chris F.
11-07-2005 16:00:44
I've had great luck at the dealer for all my "H" parts but was surprised when they said the brake pedal shaft oil seals weren't stocked anymore (354514 R91). Has anyone x-ref'd these to a "National" or other make of seal?? Thanks.
Chris F.
11-08-2005 03:55:49
 Re: Can't get 'em?? in reply to Chris F., 11-07-2005 16:00:44
Thanks for the info. guys. Would like to change those seals while things are still apart. Transmission is back together , so the worst is over?? Have a good one.
Ian T
11-07-2005 21:47:53
I did the clutch / brake cross shaft seal in my H last winter, every seal that i bought i have writing down the #'s. Clutch/brake cross shaft seal # is 476838 it's a NATIONAL seal #
Duner Wi
11-07-2005 17:00:14
Victor #49289 should fit. Shaft 1.125 in. OD 1.834 and .250 thick.
El Toro
11-07-2005 16:14:30
Call Chicago-Rawhide to see if they have a cross-reference at 1-800-882-0008. Hal
MN Scott
11-07-2005 16:14:03
That number does not cross to a CR number either. Are you sure its the correct number? I've never had a IH seal not cross to CR seals.
Nebraska Cowman
03-13-2009 14:23:07
 Re: farmal B magneto in reply to John Sadowski, 03-13-2009 13:14:52
The mark is on the end where the rotor goes. Marked L and R You want the R mark for a B
Haas
11-07-2005 19:41:47
 Re: Can't get 'em?? in reply to MN Scott, 11-07-2005 16:14:03
Scott, thanks for posting that CR seal cross reference link. It works great! I found the seal numbers I need for Super H transmission.
MN Scott
11-07-2005 16:18:29
Here's the national seal cross referance.
