Super M disk brakes
david bell /cha
11-07-2005 19:18:55
Hello Farmalls, I removed my brakes on both sides and cleaned all parts in a blast cabinet, a friend works at an aircraft repair co. -that is a great way to remove all traces of rust,- and then sprayed with green colored primer. Bought the disks at a clutch & brake shop, the owner suggested that I drill one or two holes in the bottom of the disk cover itself, 1/4" or so and then put a cotter pin in the hole. The movement of the tractor will keep the cotter pin vibrating and therefore keep the hole always open -not cloged up with outside dirt.- 2nd. It will also allow any moisture to escape,eliminating rust should the tractor be parked outside. Makes sense to me. Has anyone here tried this idea ?
IaGary
11-07-2005 19:29:43
 Re: Super M disk brakes in reply to david bell /chainsaw, 11-07-2005 19:18:55
It will never work with that "green" primer on a red tractor. Other wise the hole idea might work.
david bell / chainsaw
11-07-2005 22:36:13
 Re: Super M disk brakes in reply to IaGary, 11-07-2005 19:29:43
10-4 on that green color, I should have said zinc-oxide primer. I'll catch h*** for that mistake. Thanks IaGary
