340 LIVE PTO WONT TURN OFF
Old Hank
11-09-2005 12:25:48
Just got an old 340.
Most everything works but I cant disingage
the pto.
Please give me some advice.
Evan350
11-10-2005 08:06:40
 Re: 340 LIVE PTO WONT TURN OFF in reply to Old Hank, 11-09-2005 12:25:48
There are two adjustment screws under a cover on the PTO housing. Find your owners manual and follow the instructions. Could be the clutch is too tight or the brake is too loose, or a combination.
Janicholson
11-09-2005 15:15:54
Try turning the PTO shaft with the tractor shut off and the PTO lever in the off position. Put a lot of force on it to see if it is really off, or just coasting because it hasn't been used. The system definatly needs adjustment, because the internal brakes should stop the shaft.
JimN
