This could be bad
IaGary
11-09-2005 16:28:24
Subsoiling today and developed an oil leak above or behind fan shaft on MX 200 maybe head gasket?
K.B.-826
11-09-2005 16:43:37
 Re: This could be bad in reply to IaGary, 11-09-2005 16:28:24
I've only worked on one MX 200, but I remember that area of the engine being very cluttered and hard to see. Don't jump to conclusions until you get it cleaned up. Could be somthing as simple as the valve cover gasket.
IaGary
11-09-2005 16:55:28
 Re: This could be bad in reply to K.B.-826, 11-09-2005 16:43:37
It is lower than valve cover.It is either head gasket or theres a cover on what i believe is cam gears.I'm not atemping this one myself. Sent to Dealer maybe some dealer warranty maybe not.
Diesel Don
11-09-2005 17:13:04
 Re: This could be bad in reply to IaGary, 11-09-2005 16:55:28
Is that tractor powered by a "C" model Cummins? If so, then I think the leak is probably in the timing gear/accessory case cover gasket. The top of the case is very close to the bottom of the head.
IaGary
11-09-2005 17:20:56
 Re: This could be bad in reply to Diesel Don , 11-09-2005 17:13:04
Yes it is Cummins.I think and hope you are right. A friend told me same thing and I hope that is right. Thanks
the tractor vet
11-09-2005 16:39:56
That one is to new for me heck i ain't even been in one of them critters.
RustyFarmall
11-09-2005 17:28:08
 Re: This could be bad in reply to the tractor vet, 11-09-2005 16:39:56
I've been in one just long enough to figure out how to start it and load it on a trailer. They sure are different from an M.
IaGary
11-09-2005 17:31:34
 Re: This could be bad in reply to RustyFarmall, 11-09-2005 17:28:08
I still love to sit on my MTA in summer and rake hay. When conditions are right I still like the open air.
the tractor vet
11-09-2005 17:49:38
 Re: This could be bad in reply to IaGary, 11-09-2005 17:31:34
That is the only way but i do have a cab on my massey 410 and if i ever finish my 1486 . Heck we do a lot of farmen with S/MTA's i have one Billy has two and Vernon has one these are working tractors not setting in the shed tractors that we play with .
