Boy's Tractor
Keith-OR
11-09-2005 18:48:26
Well we got the C home this afternoon, even with truck shifter failure, that's another story. It is not a model "C" as was told, check serial # 150979 which shows it is a Super C. Now the work begins and the search for missing parts...
Keith & Shawn
old
11-09-2005 21:20:32
 Re: Boy's Tractor in reply to Keith-OR, 11-09-2005 18:48:26
If it has sat for a year or more I'd fill the cylinders with tranny fluid before you even try to turn it over. That way when you do turn it over it prelubes every thing and if things are stuck they might come loose.
Keith-OR
11-09-2005 23:14:33
 Re: Boy's Tractor in reply to old, 11-09-2005 21:20:32
Thanks for the heads up Old, had already planed on doing that. Had seen many post from you this particular subject...:-)
Keith
old
11-10-2005 05:56:39
 Re: Boy's Tractor in reply to Keith-OR, 11-09-2005 23:14:33
What can I say I like my tranny fluid and have found it works as good as MMO, and is half the cost. As a matter of fact I was out of it yesterday so I picked up a gallion. It also works good on bolts and nuts that don't want to come loose.
Keith-OR
11-09-2005 20:49:40
Thanks Nebraska Cowman and Migraine, Will be hollering at you as we get to looking things over. I already know that throttle linkage is missing. When Shawn gets home from school tomorrow going to see if we can get motor to turn over. I think I have a hand crank that will work...Again Thanks
Will try to post picture tomorrow
Keith & Shawn
migraine
11-09-2005 20:30:08
I may some extra parts you need up here in Wa. Let me know what you are looking for and I'll search the piles. Migraine
Nebraska Cowman
11-09-2005 19:58:02
I have a Super C carcass that might have some good parts left on it. Let me know if I can help.
