Different M Governor Spring
Too Far Gone
11-09-2005 19:10:23
Now we have established my tractor is a 1940 with the wrong tag on it.I took the plate off to check out the governor,and I dont have the normal Farmall Spring with a hook on both ends.This spring has a hook on one end,and the other end has a metal block with a hole in it, made in the spring and it fastens on that end with a pin through the hole fatening it to the governor arm.Its not home made.Its a factory made spring,but Ive never seen one before.Anyone got any ideas? I'll be back on here tomorrow night.Thanks so much
randy hall
11-09-2005 19:21:30
 Re: Different M Governor Spring in reply to Too Far Gone, 11-09-2005 19:10:23
that is the original spring.
RustyFarmall
11-09-2005 21:04:15
 Re: Different M Governor Spring in reply to randy hall, 11-09-2005 19:21:30
Yep, even more proof that the tractor is a 1940.
Too Far Gone
11-10-2005 15:25:48
 Re: Different M Governor Spring in reply to RustyFarmall, 11-09-2005 21:04:15
So the 1940 version even had a different gov spring than my later M's?
RustyFarmall
11-10-2005 17:31:31
 Re: Different M Governor Spring in reply to Too Far Gone, 11-10-2005 15:25:48
My 1940 H has the same type of spring that you are talking about. I like that style, you can actually tighten up the spring by rotating that clevis end on the spring and possibly improve the performance of the governor. I am guessing that the spring with clevis end was too costly to manufacture, so they did away with it.
Too Far Gone
11-10-2005 18:06:30
 Re: Different M Governor Spring in reply to RustyFarmall, 11-10-2005 17:31:31
I like that spring too.Ive never seen an old M motor open up and ball so loud.Thanks for your help
