M front bolster
Ralph L.
11-11-2005 07:38:19
Is a M front bolster same as a 400 ? Thanks Ralph
DWV
11-11-2005 08:50:31
 Re: M front bolster in reply to Ralph L., 11-11-2005 07:38:19
If the M is gasoline the answer is no.Your front
steering shaft and hood will be to short if you put the 400 on M.On MD you can interchange but won't look the same.
chadd
11-11-2005 08:24:54
If you mean are they interchangeable, they may be, only way to tell is to take measurements. Are they the same exact part? No. The M's is rounded in the front. The 400's and the Super MTA's are square and have cultivator mounting points that the M doesn't have. They may be interchangeable, but I am not positive.
Aces
11-11-2005 08:05:06
Ralph Should be.
