Re: governor linkage
gene bender
11-12-2005 06:02:58
With engine off open throttle wide open. The clevis that goes to the carb from the gov you want to remove the pin. After pin is out hold the linkage to open the carb wide open and adjust clevis so the pin goes in free. The input shaft on the gov can be repaired to eliminate side sloppiness and mite want to replace the gov spring also. I find when everything is in good shape the throttle will work just fine.
