Done seen it all .
the tractor vet
11-12-2005 15:28:43
Now i have seen everything Went and looked at some tractors today that are going upfor auction and one old rough M had live power and power steering and it had the standard I H pump for a super M on and also a piggy back pump on the back of it then the dist the cap was so tight against the oil filter that you would have to pull the oil filter to get the cap off. But did have good tires the rest well it would take some work.
RustyFarmall
11-12-2005 17:48:38
 Re: Done seen it all . in reply to the tractor vet, 11-12-2005 15:28:43
I'll bet the power steering was a Behlen unit. That unit alone will put the dist. cap pretty close to the filter. Adding another pump into the mix would only make it worse.
