SUP WDR9 PARTS
LBYJ
11-12-2005 19:39:25
LOOKING FOR SOURCE FOR ENGINE PARTS-ALSO REFERENCES FOR PARTS OFF OTHER IH'S THAT WOULD
BE THE SAME--M OR TD9 ETC? MAG OR DISTRIBUTOR
TYPES THAT MIGHT FIT. ANY HELP, THANKS LB
BIG JOHN
11-13-2005 17:00:06
 Re: SUP WDR9 PARTS in reply to LBYJ, 11-12-2005 19:39:25
Don't know where you are but Mike at Steel Wheel Ranch will have everything you need and he knows them inside and out. WWW.steelwheelranch.com
GOOD LUCK
Roger in Iowa
11-13-2005 15:34:17
Watch out for interchangeability on mags and distributors. Rotation is different on different models therefore the advance actually retards if installed on wrong unit. This is not 9's to 9's but maybe A's or C's or M's to 9's.
Roger in Iowa
El Toro
11-13-2005 04:11:23
weberstractorworks.com have sleeve and piston kits. I think the TD9 may use the same engine.
Hal
