403 combine engine
Allen Regnier
11-13-2005 07:21:03
Does anyone know what tractors have the same
engine as a gas 403 combine. I want to save a
good engine off of an old combine. Thank You.
Allen Regnier
11-18-2005 16:51:03
 Re: 403 combine engine in reply to Allen Regnier, 11-13-2005 07:21:03
Thanks everyone for the info. This saved me hours of research. Al
Former 403 Owner
11-13-2005 08:09:58
The only gas engine ever used in the 403 IH combine was the C-263 rated at 90 hp at 2400 rpms.That engine was also used in the 560,656,706 tractors.
The D-301 diesel was also offered in the 403 too.
We once owned a 1963 403 gas combine.
El Toro
11-13-2005 07:55:16
My manual list's the C-263, C-153, C-221, and C-282 engines for the 403 combine. The C-221 will fit the 460 tractor. The C-153 may be the H engine & the C-263 for the Super M unless they're
not the same engine used in the tractors. I would doubt that. Hal
the tractor vet
11-13-2005 11:02:19
 Re: 403 combine engine in reply to El Toro, 11-13-2005 07:55:16
C 263 was a 6 cylinder and the 264 was the 4 banger that was in the S/M
Stan(VA).
11-13-2005 16:22:35
 Re: 403 combine engine in reply to the tractor vet, 11-13-2005 11:02:19
Also the C153 is the 504/444 engine (sleeveless bored & stroked motor from the C113/C123/C135 line). The H motor was a 152 incher.
Stan(VA).
Charles McNelly III
11-15-2005 16:24:43
 Re: 403 combine engine in reply to Stan(VA)., 11-13-2005 16:22:35
Will the crank out of the C-153 bolt up in a C-113? Sounds like I need one if it does.
El Toro
11-13-2005 11:31:57
That is right. Thanks, Hal
