Jacking up the rear wheel
Elk Farmer
11-13-2005 14:15:55
What is the best way to jack up one rear wheel. Can you put a jack under the axel housing? Is it better to put the jack towards the middle of the tractor or more to the outside of the axel housing. I have to move one tire in on my H.
Thanks
Carl from Michigan
wolfman
11-13-2005 19:19:13
 Re: Jacking up the rear wheel in reply to Elk Farmer, 11-13-2005 14:15:55
Can put jack under housing -find a flat spot. I always put cribbing blocks under the drawbar or somewhere just in case!
RustyFarmall
11-13-2005 16:10:55
I use a heavy floor jack under the horseshoe drawbar.
CNKS
11-13-2005 14:27:18
Put it under the axle housing, and be sure to keep your feet out from under the wheel. Most jacks are not very stable, particularly since you will have to rock the wheel to get it to move. A jack stand under the axle is safer if you are actually removing the wheel.
KX2B
11-17-2005 12:47:05
 Re: Jacking up the rear wheel in reply to CNKS, 11-13-2005 14:27:18
"A jack stand under the axle is safer if you are actually removing the wheel." Thats good advice since you may have to beat on it some to break it free.
