crankshaft pulley
RN in Misissipp
11-13-2005 15:32:53
&*^&*$#@*** crankshaft pulley!!! I've already spent 60 bucks to have the machine shop pull it off and then, after putting the engine back together on my 100, I get it back on just up to the front seal but that's as far as she goes. Then, I mis-hit the wood block I'm using to hammer it on and I knock a big chunk out of the front of the pulley. I've got no heat (or enough heat) to heat it up and nothing to pull it back off and try again.
Any suggestions? I can't figure out why this thing was engineered to be such a tight fit.
El Toro
11-15-2005 05:50:45
 Re: crankshaft pulley in reply to RN in Misissippi, 11-13-2005 15:32:53
Which tractor is this? Hal
PS: What's the diameter of the pulley?
Hobo,NC
11-14-2005 05:43:24
third party image
Plate used to remove crank pulley
El Toro
11-13-2005 17:50:41
You should've had a puller made like this using a hydraulic jack or ram. That pulley is a press fit. That's why it fit's so tight. You need to heat it in your oven at about 250 degrees in your oven. This will slightly expand the hub long enough for you to install the pulley.
With this puller you still need to use a split bearing separator behind the pulley to pull or push against. The flanges of the pulley will break easily. Hal
PS: Your local metal shop can make one for about $35.00 and you would need to buy 3/4 allthread with flat washers and nuts. Here's a web site for salvageyards in your locality too.
Link
http://www.epartdirect.com/index.php?t=fc&s=s
Hobo,NC
11-13-2005 17:34:25
I gotta git yer Farmall boys a pix of a HO-MADE tool to pull yer front pulleys, its in the werks. i mostly play with the ford N,s but in'joy look'in at the Farmall stuff and the action you have over here, a good group of contributors.
A good bear’in splitter izz not cheap so its not a hobbie mans tool. You kin and need a cheap 2 jaw puller. The plate I use izz a 7/16 thick piece of steel plate or you kin use a thicker plate the one I have izz one I got out of the scrap pile. Imagine a horse shoe when I discribe it. 6- 6/4” wide, 7- ˝” long and the middle of the horse shoe “U” izz 2 5/8”. A touch will cut it out fit it around the back side of the pulley and use the 2 jaw puller to remove the pully with the jaws pull’in on the horse shoe “U” it werks and I have never broke a pulley. They do make a pully installer but they are not cheap either. I have one but most of the time use a air hammer to knock’em on. I will git ya a pix of the Horse shoe plate “U”
the tractor vet
11-13-2005 16:36:11
A large gear puller and bearing spliter.
