Rubber hose connecting air cleaner to carb--Farmal
Blue3992
11-13-2005 16:38:23
The rubber hose connecting the air cleaner pipe to the carb on my M looks pretty rough. What"s the best way to get a replacement? Do I need to just buy a radiator hose that"s the same diameter and cut off the section I need?
KirkMn
11-16-2005 18:20:50
 Re: Rubber hose connecting air cleaner to carb--Fa in reply to Blue3992, 11-13-2005 16:38:23
I cut a piece of leather and wrapped it around and clamped it. Worked good. Gas wont eat it up.
john in Ct
11-13-2005 19:08:49
Don't use radiator hose. The gas from the carb will eat it. Get the right hose from IH or any place that sells hose that can take gas. It will cost more than radiator hose.
gene bender
11-14-2005 03:57:56
 Re: Rubber hose connecting air cleaner to carb--Fa in reply to john in Ct, 11-13-2005 19:08:49
Been using radiator hose for 50pluss yrs now and it works. Anyway gas aint supposed to be running out of carb. I-H dealer will cut off length from bulk radiator hose also.
MN Scott
11-13-2005 18:54:38
I get mine from my CNH dealer, he just cuts off a peice the size I need from a roll of it.
gene bender
11-13-2005 17:15:32
Just take the old hose to any parts store that has bulk hose.
CNKS
11-13-2005 17:14:00
NAPA has it. I have several tractors, when I buy hoses like that, I will buy a foot or so to have enough for the next time. Unless you have a very sharp knife and can cut straight, a tubing cutter is nice too.
farmallhal
11-13-2005 16:53:55
Hose size is 2.25" ID by 2.25" long - 8 ply per the parts catalog. OEM at 1-800-283-2122 has them for sale at $5.00 in their catalog. With shipping might be a little much unless you need other items. Check with NAPA or other good autoparts store - don't know if 2.25" ID is common or not. Good luck. Hal
