How to split a 400
400
11-13-2005 16:43:39
Will the frame rails on a 400 hold up the front half of the tractor without the motor tilting backwards or do you need to support the rear of the engine?
the tractor vet
11-13-2005 16:58:40
 Re: How to split a 400 in reply to 400, 11-13-2005 16:43:39
There are two ways to do this , one is to make up a set of splitting stands that are fully adjustable and have steel wheels and hook them to the frame rails and leave the top bolt and bottom bolt on each side in the holes into the rear engine plate this will hold the engine if not it will break the ft. off. Second way is to make up a set of stands that don't move and use a good size floor jack and roll the back away , myself i like to leave the rearend in one spot and roll the ft.
