Regular International Carburator
James Autry
11-13-2005 18:35:46
OK,I need some advice from you experts. How do you take apart the International carburator via stem nut? I see the ends of this, but do not see a way to remove it without breaking something. How is this removed, and the parts separated??? Thanks
Sloroll
11-14-2005 04:35:09
 Re: Regular International Carburator in reply to James Autry, 11-13-2005 18:35:46
Remove the stem nut and lightly tap on the unit with.. something. The top and bottom will separate. YOu may have to wiggle things a bit to get the vent out of the venturey
James Autry
11-15-2005 07:44:03
 Re: Regular International Carburator in reply to Sloroll, 11-14-2005 04:35:09
I think the hangup here is removing the stem nut itself, how is that done?? I do not see anything get a wrench around.
pgo12
11-15-2005 14:50:39
 Re: Regular International Carburator in reply to James Autry, 11-15-2005 07:44:03
there are 3 different carbs listed in my parts book. an ensign 3da 600f 1 inch, a zenith st5, and an ensign model r 1.25. i think there might be one or two others, which one do you have? pg
James Autry
11-15-2005 15:04:59
 Re: Regular International Carburator in reply to pgo12, 11-15-2005 14:50:39
Neither Ensign or Zenith, it is tagged as an International carburator.
