Pic as promised son's Farmall
Keith-OR
11-13-2005 20:17:23
third party image
Here is the picture of Shawn and his little sister(Sheana) With his new, to him, Farmall C. Motor turns over fine. Checked oil in pan,looks like it hasn't run much since it was changed. Have taken off gas tank,seat,hood and grill. Going to start one of them in electrolysis tank tomorrow. Little sister sure like helping big brother with his tractor. I gave her a socket and ratchet,showed her how to remove few bolts....
Keith
gab
11-14-2005 19:17:01
 Re: Pic as promised son's Farmall in reply to Keith-OR, 11-13-2005 20:17:23
third party image
If this works, this tractor looked about Shawn's, except his has got better sheet metal. Jim
ga b
11-14-2005 19:12:26
If this works, this tractor looked about Shawn"s, except his has got better sheet metal. Jim
Keith-OR
11-14-2005 12:02:32
Hal tractor belongs to the boy sitting on it, he is handycapped, trying to find something that he can do. Don't think he will ever beable to drive it, but we will see. He has the best help around, little sister!! Gene it does have the 100 inch axels. And 55-60 did come with both carb and air cleaner, but was not attached to tractor. Carb needs to be tanked and rebuilt, but does not have the throttle linkage....Thanks everyone
Keith & Shawn
farmallhal
11-14-2005 10:38:32
Looks like a nice tractor to restore. I saw several of them in a lot worst condition when I was looking for a SC. I'm sure you will enjoy the project and will have a great useable tractor when done. Hal
55 50
11-14-2005 09:08:58
Looks like no carb or air cleaner. Did it come with those parts loose?
gene bender
11-14-2005 03:44:41
Also looks like those are 100in axles.
dennis in or
11-13-2005 23:13:26
keith, keep your eye out for me . i like that one
Keith-OR
11-14-2005 05:44:59
 Re: Pic as promised son's Farmall in reply to dennis in or , 11-13-2005 23:13:26
Hi Dennis, friend is still looking for another Super C, so if find another good one will let you know....
Keith & Shawn
BobG in VA
11-13-2005 21:04:23
If I'm not mistaken, that's a Super C rather than a C. Looks like about the right gap between the fuel tank and the hydraulic block, whereas C didn't have any gap. Also, the voltage regulator is below the generator. check the Serial No. If its a 6 digit number its a Super. If its a 5 or less it would be a C. Good Luck with it! PS, Hold on to those front wheel weights, they're worth $50 a piece or more. BobG in VA
Keith-OR
11-14-2005 05:37:40
 Re: Pic as promised son's Farmall in reply to BobG in VA, 11-13-2005 21:04:23
Yep, you are corrct. I checked the serial # when got it home Wed. just did not put super C in subject matter. And if I tell him that he will think he is Superman...Thanks....lol
Keith & Shawn
old
11-13-2005 21:04:03
Looks like shes pushing to hard on the tire and made it go flat. LOL
Keith-OR
11-14-2005 05:41:38
 Re: Pic as promised son's Farmall in reply to old, 11-13-2005 21:04:03
Morn Old, I think so. She did it as she likes to pick on her older brother...we only get her every other week-end....thanks
Keith & Shawn
