SUPER M STARTER RODS
Tom F
11-14-2005 12:55:01
my '52 stage 1 super m has the starter pedal that attaches to the steering post by means of a bracket. I never thought anything about it until I viewed an illustration from my operators manual. My manual was published in april of 1952, the same period my tractor was made. The picture shows a simple short rod inserted through a drilled hole in the steering post that directly contacts the starter button. i removed my pedal bracket and it found that my steering post has this through hole for the short rod also. My grandfather took pictures of the tractor the day he bought it and it came with the pedal style starter rod. was the pedal style an option? is my current setup correct? thanks!
John A.
11-14-2005 20:01:19
 Re: SUPER M STARTER RODS in reply to Tom F, 11-14-2005 12:55:01
Tom, I looking at Stage I SM with a pushrod on the starter too. It is different, but a factory setup to my knowledge. OBTW...It is an LP with the Stage II croswise tank. with the rear faceing valves.
Later,
John A.
DWV
11-14-2005 16:39:19
Tom, can't remember ever seeing the starter button pin on a SM but I looked in a SM parts book and sure enough its shown for stage 1 tractors.The one you have is correct though.Did the picture you looked at with starter pin show a
seat with pipe frame and spring in front also?
I think when they started offering the hydraulic
seat most were equiped with the lever type linkage because it was hard to get your foot on pin with later seat frame.I should make clear it shows the lever type in parts book also.
DWV
11-14-2005 16:45:53
 Re: SUPER M STARTER RODS in reply to DWV, 11-14-2005 16:39:19
Forgot to mention the hydraulic seat and lever
style linkage started being offered during regular M production.
Tom F
11-15-2005 07:01:10
 Re: SUPER M STARTER RODS in reply to DWV, 11-14-2005 16:45:53
DWV, The illustration I saw had the hydraulic type seat. Restoring this stage 1 can be confusing. Some parts are regular M parts and some are super m parts. I have to look at it for the most part as a M with the 264 engine and disk brakes!
