Hyd Leak
Florida Tom
11-14-2005 19:30:43
I have 1958 Cub, and I seem to have a slow Hyd Leak and it's coming from the bottom of the hdy resvior. It almost is weeping oil over night. I don't have any idea on how to correct this, and I am looking for some advice. Thanks
Tom
scotty
11-15-2005 06:06:00
 Re: Hyd Leak in reply to Florida Tom, 11-14-2005 19:30:43
Hi Tom, I have a Super A, not a Cub, but the units have a similar setup other than the Cub only has one piston I believe. If you are getting a leak from the bottom of the unit, you will need to remove the touch control unit from the tractor, remove the bottom plate and install a new gasket. Not a difficult job, other than draining the system. Hope this helps.
scotty
