farmall m 1951
Michael21
11-15-2005 08:41:19
I have a view window by the starter on my 1951M, Is this how I check the fuid level? also what kind of fluid and how much goes in? I put a screwdriver in there and the stuff on the end of it was dryed up and sticky. Thank you if you can help me
Wayne Swenson
11-15-2005 18:41:24
 Re: farmall m 1951 in reply to Michael21, 11-15-2005 08:41:19
What fluid are you looking for?
Engine oil is checked using the petcocks on the side of the oil pan; transmission oil is checked with level plugs on the side of the transmission housing.
Please get yourself an owner"s manual or a "Serviceman"s Guide" for your M. Best $$ you will ever invest for your tractor.
captaink
11-15-2005 09:34:57
I know of no view windows in the proximity of the starter on the 51 M but there is a little hole or port with a swing away cover that opens into the torque tube cavity allowing you to grease the throw-out bearing. I’m guessing that what you found was old grease either dropped from the head of the grease gun or slung out of the bearing lying on top of the liftall pump.
The check for the fluid level is in front of the belt pulley housing on the opposite side of the tractor. It has a cap that looks like a knob on top of a pipe and there is a dip stick under that cap. The transmission level check is a pipe plug on the clutch side of the rear end housing in front of the clutch about the same level as the rod between the clutch petal and the shaft that goes into the torque tube. You have the correct level of lubricant in the rear end when it dribbles out of this hole.
