Farmall Super M Flywheel Depth for Clutch
LumbrJakMan
11-15-2005 12:52:52
Hello. I just had my Flywheel resurfaced. The Clutch Disc is free floating after PressurePlate is Bolted tight . Does anyone know the depth I am sposed to have for a Factory Fit ?
Thanks .....
LumbrJakMan
11-15-2005 15:20:29
 Re: Farmall Super M Flywheel Depth for Clutch in reply to LumbrJakMan, 11-15-2005 12:52:52
Well I will PROMPTLY order my "Greenhorn" Sweatshirt tomorrow . CaptainK , you hit the Nail on the head. I did Remove the 3 Bolts holding the Pressure Plate down and The Clutch fits snug . I am Tackling my First Engine rebuild on a Super M , and Learning a Lot. Thanks For the advice.
Allan in NE
11-15-2005 16:08:41
 Re: Farmall Super M Flywheel Depth for Clutch in reply to LumbrJakMan, 11-15-2005 15:20:29
Jak,
'Taint nothin' wrong with that. Everyone has to do his first one sometime.
If ya get cornered, give a hollar, 'cause there are some pretty sharp ol' boys hangin' out here. They are forever helpin' me on my little projects.
Good luck on your build and shoot us some pictures?
Allan
the tractor vet
11-15-2005 13:31:50
The distance from the step to flywheel face is 1.406.
captaink
11-15-2005 13:25:25
Are there three bolts in the pressure plate assembly holding the pressure plate away from the clutch? These bolts are located in the radius between the spring holders. If these bolts are installed, the clutch will float free.
I don’t know the measurements off the top of my head, but the machine shop should have resurfaced the area where the pressure plate bolts to the flywheel the same as the clutch surface.
