Brake drum
magneto
11-15-2005 15:43:07
I've rigged up a puller, backed off the set screw
and applied heat with my torch but I can't get that brake drum to budge. Any suggestions?
EricB
11-16-2005 04:38:18
 Re: Brake drum in reply to magneto, 11-15-2005 15:43:07
I suppose you've done all this but if the brake drum will rotate it should be free enough to come off. Sometimes the shoes get pulled off kilter and jam. Will it move forward at all? A combination of tapping with a heavy hammer and pulling may keep the shoes from catching. Check that there is no drag tension on the hand brake cable.
When you do get it off, consider replacing the springs.
Janicholson
11-15-2005 15:46:10
We love to help. What is it you are working on, my fishing reel has a brake drum on it.
JimN
magneto
11-15-2005 15:45:22
I forgot to mention the brake drum is on a Farmall B (right hand side).
