Farmall M belt pully
Phillip Womble
11-15-2005 16:46:27
I have a 51 Farmall M that has no belt pully. I have located what appears to be a complete belt pully gearbox, but decided not to buy it until I ask the experts here about installation. How difficult would it be to install a belt pully gearbox on my M?
THANKS!! P.Womble
F-Dean
11-16-2005 11:55:16
 Re: Farmall M belt pully in reply to Phillip Womble, 11-15-2005 16:46:27
Make sure it is for an M -- That is, the "In-Out" lever points to the driver's right and has a dog-leg in it. Also, if possible, try to get the lever that shifts the pulley in and out of gear.
NDS
11-15-2005 17:26:25
Not hard at all just remove plate install new gasket set it on and bolt it down. You should try to get original bolts as a few of them are rather long and probaly not available at typical hardware store.
