farmall b ignition
walter south te
11-15-2005 19:09:55
i am restoring a 41 farmall b and would like to know what is better. it has a magnito type ingnition (the cap sits horizonal), but i have a spare dist. type ingnition (sits upright with external coil) what would you used on it.
JohnG(TX)
11-16-2005 11:59:14
 Re: farmall b ignition in reply to walter south texas, 11-15-2005 19:09:55
Walter, what part of S. Texas are you in? I have seen this kind of problem before and used a points file to fix it. Just file the points until they are clean.
JG
walter south texas
11-17-2005 18:27:29
 Re: farmall b ignition in reply to JohnG(TX), 11-16-2005 11:59:14
alice texas
Dave BN
11-15-2005 22:10:39
If your truely restoring it I would use the mag as it would be the origional equipment. Dave.
old
11-15-2005 19:20:59
Well if the mag is good I'd go with the mag. That way it will run even if the battery goes dead. Plus you can hand crank it even with a dead battery.
walter south texas
11-15-2005 19:40:38
 Re: farmall b ignition in reply to old, 11-15-2005 19:20:59
the mag doesn"t fire but i think i can fix it
El Toro
11-16-2005 06:24:06
 Re: farmall b ignition in reply to walter south texas, 11-15-2005 19:40:38
You need to check the magnets for magnetism, this is what makes your coil fire. Use a flat blade screwdriver and see if those magnets grab that screwdriver. Very little magnetism is a sign the magnets are or are getting weak. I would do this before buying a lot of parts. Parts are available for the IH mag. Hal
old
11-15-2005 20:29:59
That can be as simple as bad points/condenser. Or as bad as a bad coil. Rebuilt mags aren't cheap, last one I got was around $250
walter south texas
11-16-2005 05:48:50
 Re: farmall b ignition in reply to old, 11-15-2005 20:29:59
yea i haven"t looked into the mag to see how the points/condenser look. this tractor was running then was parked and set there. so it should be to bad to get the mag going.
old
11-16-2005 08:20:30
 Re: farmall b ignition in reply to walter south texas, 11-16-2005 05:48:50
True Mag don't go bad just from sitting unless they get a lot of water in them, but points do. I'd almost bet a new set of points and a new condenser will fix that mag.
