Valve settings
Delbert Doty
11-16-2005 07:01:33
I need to know what is the proper valve tappet settings for the 1952 Farmall engine.
Where can I find a operator or owner manual for this tractor?
Any help will be great, Thanks
Delbert Doty
11-28-2005 11:48:28
 Wiring harness in reply to Delbert Doty, 11-16-2005 07:01:33
I have a short in my wiring on 1952 Farmall H.
Can anyone sudjest a source for a new harness or where to start to fix problem.
6 Volt system,
robertw
11-16-2005 12:18:25
 Re: Valve settings in reply to Delbert Doty, 11-16-2005 07:01:33
Delbert i got the book out after i posted the follow up and it said .017 warm instead of .018 sorry about that i think i'am telling you my age
RustyFarmall
11-16-2005 11:44:19
O.K., now that we know it is a Farmall H, we can simplify it a bit. With the engine cold, set the valve gap at .020". It will be right in the ball park when it is good and warmed up.
robertw
11-16-2005 11:28:58
I have a 1953 farmall sh that i just set the valves on and the corect setting was .018 that was out of the orginal book with the tractor i would think the regular h is the same
Bob
11-16-2005 07:30:48
Knowing what model you have would help. Here's a link to tune-up specs on this site.
Link
Here's how to position the engine:
Link
This very site sells SOME manuals. Here's that link:
Link
Your nearby CNH dealer should still be able to get them, and Binder Books has a reputation for top-quality reprints. You'll have to Google that one!
Delbert Doty
11-16-2005 10:53:01
 Re: Valve settings in reply to Bob, 11-16-2005 07:30:48
Thanks Bob I was out on thr manufracturing floor when I relized that I had left out my tractor is a Farmall H, 1952 4 cylinder 152 cu. in.
