Order Farmall Cub Parts Online
1952? Cub Questions
BillA
11-16-2005 11:06:48
Looking into buying a Cub and have a question or two. Other than checking for the normal water in oil type stuff, is there any particular defect/problem area that I should pay attention to? The tractor runs very well, looks good and has a good set of implements in good condition. The only things noticeable are a little play in the steering, wants to run a few minutes then shut off like it is out of gas but restarts with a minimal amount of hesitation (probably dirty carb and/or fuel system) and I notice as it is running after it has warmed up smoke comes out around the oil filler/dipstick area. I don't expect a flawless tractor, but one that offers good potential without a major investment on repairs. I am comfortable working on it mechanically wise, but if one of the things I mentioned is a tell-tale sign of something to bite me I would like to know.
Of course like any other purchase of used equipment it is still a crap-shoot.
Redned
11-16-2005 19:18:47
 Re: 1952? Cub Questions in reply to BillA, 11-16-2005 11:06:48
BillA
Check this out!
http://www.antique-tractor.com/CubFAQ/cub_faq.html
Missouri Boy
11-16-2005 16:37:36
I do not want to be a smart alec but the best thing to look for when considering a Cub is a Super A. Both usually sell for same price and the SA is a much better tractor, I have a Cub and SA not much difference in the overall size
old
11-16-2005 12:24:07
Check the fluids in all places, hyds and tranny. The tranny like to get water in them which isn't a real big deal but will need to be fixed if you do buy it. The smoke from the dipstick is probably caused by blow by which means the rings maybe a little worn
BillA
11-16-2005 12:54:39
 Re: 1952? Cub Questions in reply to old, 11-16-2005 12:24:07
What would the source be for the water in tranny?
old
11-16-2005 13:02:25
 Re: 1952? Cub Questions in reply to BillA, 11-16-2005 12:54:39
If it has ever sat out side in the rain what happens is, rain water runs down the shifter and then in to the tranny. We have a cub that we put all new seals in the tranny last summer and hwne I checked the tranny it was over full and the fluid was milky looking. It had been parked out side since we had done the work to it and as I said it come in from the shifter. Its no big deal but need to be looked at.
El Toro
11-16-2005 13:01:39
Most likely hasn't been sheltered from rain or snow or both. Makes a big difference when stored under a shelter. Those C60 engines aren't sleeved. Hal
