fuel pump IH 756
Russell Venier
11-16-2005 12:46:41
I was wondering if anyone knew how to turn up a fuel pump on an international 756. It has a rotary pump on it and i only know how to turn up inline pumps. Please e-mail me if you can help. Thanks
the tractor vet
11-16-2005 14:05:28
 Re: fuel pump IH 756 in reply to Russell Venier, 11-16-2005 12:46:41
That is not rocket sience to do that Where your shutdown cable hits the stop on the run side just loosen the cable and then loosen the nuts that lock the stop and back out a littel about a turn to turn and a half . If ya go to far then it is China Syndrom then yo'll be asken on how to rebuild .
RUSSELL VENIER
11-17-2005 14:19:56
 Re: fuel pump IH 756 in reply to the tractor vet, 11-16-2005 14:05:28
THANKS FOR THE HELP I AM GONNA GIVE THAT A TRY WHEN I GET HOME.
IaGary
11-16-2005 15:16:35
Tractor vet does that increase RPMs as well as fuel flow. Is that a rosa master pump like on my 856.
K.B.-826
11-16-2005 16:43:31
 Re: fuel pump IH 756 in reply to IaGary, 11-16-2005 15:16:35
No, that does not increase RPM, just fuel. No, 756 does not have a Roosa-Master, it's a Robert Bosch rotary.
Ia Gary
11-16-2005 17:47:18
 Re: fuel pump IH 756 in reply to K.B.-826, 11-16-2005 16:43:31
Thanks K.B.826 I was just wondering because I increased RPMs just a little on 856 years ago but I wasn't wanting to turn up fuel and didn't think I did by adjusting RPMs.
K.B.-826
11-16-2005 18:24:35
 Re: fuel pump IH 756 in reply to Ia Gary, 11-16-2005 17:47:18
No, you didn"t increase HP by increasing max rpm.
Nat
11-17-2005 05:25:13
 Re: fuel pump IH 756 in reply to K.B.-826, 11-16-2005 18:24:35
Now I came on here about a year and a half ago and got told that increasing fuel increased RPMs...
K.B.-826
11-17-2005 20:01:05
 Re: fuel pump IH 756 in reply to Nat, 11-17-2005 05:25:13
Well I didn't tell you that. "Turning up" the pump is nothing more than adjusting the amount of fuel delivered at rated speed. It has no effect on high idle speed. You could certainly adjust high idle speed to increase max RPM, but why?
RUSS VENIER
11-18-2005 13:38:09
 Re: fuel pump IH 756 in reply to K.B.-826, 11-17-2005 20:01:05
I JUST WANT TO TURN UP THE FUEL SOME NOT THE RPMS. LAST NIGHT I MOVED THE STOP ON THE RUN SIDE OF THE FUEL SHUT-OFF OUT ABOUT A TURN AND A QUARTER. NEED SOME DRY GROUND TO TEST IT ON
IaGary
11-17-2005 17:10:05
On the 414's and 436's motors I turned up fuel all the time but it never increased rpms.
