Putting a WF on a 350D
Brooks McCormic
11-16-2005 13:03:35
I have a 350D with the narrow front, also have a IH wide front(tie rod in back). How difficult is it to put on that tractor? If possible, how is it done?
Any help is appreciated.
Hugh MacKay
11-18-2005 00:37:09
 Re: Putting a WF on a 350D in reply to Brooks McCormick, 11-16-2005 13:03:35
Brooks: If that wide front came from a Super H, 300, 350 or 460 it will bolt right up to your tractor. If it came from Super M, 400, 450, 560, 656, etc. you may need to modify or replace the parts that actually bolt to front of tractor. Bolt spacing is different on these larger chassis tractors. The actual adjustable axle is exactly the same.
Harold H
11-17-2005 06:05:52
Depends on what the wide front axle came off of.
