706 806 throttle
stu in njo
11-17-2005 08:28:36
The throttle lever on the two tractors is sloppy I have made them as tight as I can no help. Is there a way to bush them? Right now the idle is all over! Thanks Stu
Ernest
11-17-2005 09:51:09
 Re: 706 806 throttle in reply to stu in njo, 11-17-2005 08:28:36
If your shaft coming out of the "dash" is good drill it out and drill thorottle lever out and insert a larger pin. If not weld the hole shut in the dash redrill it out and pin it?
