Piston ID
Dave H (MI)
11-17-2005 17:11:39
third party image
I'm gonna try to post a pic of this thing. Maybe someone knows what it is, how it was used, etc?
Pretty sure it is IH from a very tiny logo on one end. Was told it was a lift-all cylinder but...???
gene bender
11-19-2005 04:33:53
 Re: Piston ID in reply to Dave H (MI), 11-17-2005 17:11:39
There were several different length of the extensions at the end of the piston throw. Before you get some more cycls better make sure you have the correct total length for the imp you are using it on. Plows and discs used a shorter one that you have pictured although you can always saw the end off to make it work. They all had the same stroke which was standard 8in movement. Ones on cotton pickers were realy long.
randy hall
11-17-2005 20:19:02
lift-all cylinder
Allan in NE
11-17-2005 17:17:25
Yep,
That's an old one direction cultivator cylinder.
Allan
RustyFarmall
11-17-2005 17:54:51
 Re: Piston ID in reply to Allan in NE, 11-17-2005 17:17:25
Yep, I agree, it"s a cultivator cylinder.
Bob
11-17-2005 17:47:57
Older windrowers used a similar unit for reel lift, ousing cables off of a tower on one such cylinder.
Janicholson
11-17-2005 17:16:08
IH cylinder commonly found on cultivators and other implements both mounted (pickers) and pull behind (discs and plows)
One way fairly fast operating and pretty good for reliability.
JimN
Dave H (MI)
11-17-2005 19:34:15
 Re: Piston ID in reply to Janicholson, 11-17-2005 17:16:08
Sounds like I got what I wanted, thanks guys! Let's see, one more and then some cultivators and.....
