Farmall B antifreeze
Dave H (MI)
11-18-2005 11:30:45
I got lucky. What I did not care to mention in the previous post was that, while I completely forgot to check the antifreeze in the B the temps here went down in the teens. Been dreading going out there and working on it but when I opened the drain I found it was full of the prettiest green stuff I think I've seen. Thanks for all the info below!
El Toro
11-18-2005 11:41:57
 Re: Farmall B antifreeze in reply to Dave H (MI), 11-18-2005 11:30:45
You're very lucky. Hal
PS; You should drain & flush the system every 2 or 3 years and add a new mix.
