B Left Brake Pedal Removal
garrett_tx
11-18-2005 13:09:48
Trying to get the left brake and clutch pedals free from the torque tube to clean them up so they rotate a little smoother, but I can't get the left brake pedal off the shaft that connets it to the torque tube. I removed the bolt that goes through the pedal and into the shaft. The parts catalog doesn't show anything else that would be keeping the pedal on the shaft. I tried using a puller on the pedal, but only managed to break the corner of the pedal off. Any suggestions would be appreciated.
gene bender
11-19-2005 04:09:07
 Re: B Left Brake Pedal Removal in reply to garrett_tx, 11-18-2005 13:09:48
Heat will probably the best as they have been on for 50 pluss yrs and sometimes they just aint no fun. If the tapered bolt is out there is nothing else holding except rust. Be carefull not to bust the casting on the torque tube holding other end by the clutch pedal. I have parts if you need some.
