Keith in Oregon Super C Parts
migraine
11-18-2005 19:29:55
Keith I went to the yard and found the parts you are looking for. One of the yard men lifted up the torque tube so I could remove the parts. Should have all you need including the clutch release shaft , the clutch release lever and the long clutch release rod in the tube. I did not know if you needed it but it was already unhooked from the bearing holder so I took it all . Let me know if you want me to send it and where. Have the key as well pretty tight fit I might say. Regards Migraine (aka Howard in Wa )
