Just what does that little spring do? 504 brakes
TWL
11-19-2005 09:58:03
There is a spring inside the drum that attaches to the actuator and to a pin.This pin is almost like a rivet and has broke and now there is no where to attach this spring to.What would happen if I left it out.Thank you for your help
Aces
11-20-2005 13:34:31
 Re: Just what does that little spring do? 504 bra in reply to TWL, 11-19-2005 09:58:03
TWL The problem with the disk brakes is that they crab. Part of this is do to the actuator rotating some and that spring is there to help staop that. The 656 came with dowel pins so they can't rotate.
TWL
11-20-2005 17:20:22
 Re: Thank you Aces in reply to Aces, 11-20-2005 13:34:31
Thank you for the information.I am going to fix the spring.
