M OR SUPER M
alan king
11-19-2005 10:31:30
DID THEY MAKE ANY SUPER M FARMALL WITH THE BATTERY NOT UNDER THE SEAT. ALSO THIS TRACTOR HAS 3 HUGE WHEEL WEIGHTS ON EACH WHEEL. 2 ON EACH INSIDE AND 1 ON OUTSIDE. IS THIS A FACTORY THING OR WERE THEY ADDED SOMETIME. THANKS
John A.
11-19-2005 20:37:23
 Re: M OR SUPER M in reply to alan king, 11-19-2005 10:31:30
Alan, The Stage I Super Ms Do Not have the batt under the seat. They look just like a regular ol garden variety M. Monroe shock seat (the litte short one). The hydrolic pump is in the belly of the tractor. The only 2 distinguishible points that are readly obivious to the regular Joe is ...
1 the 264 engine.
2 the disc brakes.
The Battery didn't get moved to the underseat position till the Satge II series. Hope this helps.
Later,
John A.
r4etired
11-19-2005 17:57:42
The early super M should still have the belly hyd pump, bulb lites, disc brakes,Fast fourth, straight gear shift and 264 engine,
DWV
11-19-2005 12:09:41
If this is same tractor you ask about before,the tractors with battery under gas tank have a lower serial # than # you posted.
Hugh MacKay
11-19-2005 13:37:00
 Re: M OR SUPER M in reply to DWV, 11-19-2005 12:09:41
DWV: Amazing the lengths some folks will go to, trying to convince themselves they have a Super.
Steven@AZ
11-19-2005 11:10:12
Yes, they made a Super M with the battery not under the seat.
Weights were an option, they should just be bolted to the wheel casting.
THEkyroastnear
11-21-2005 16:29:18
 Re: M OR SUPER M in reply to Steven@AZ, 11-19-2005 11:10:12
i own a super m with battery not under seat by serial plate it is 53 model with live hydr. &power steering a add on im sure char-lynn
