Clutch adjustment
Clutch problems
11-19-2005 11:33:01
I have a 400 Farmall that the clutch is not releasing good and need more adjustment. I have the linkage between the pedal and the clutch arm adjusted with almost all the free travel out and you still have trouble getting it into gear. The pressure plate fingers have adjustments on them near the pivot point (not where the touch the throw out bearing). Would adjusting the fingers change the geometry and make the pressure plate release the clutch plate any more? I just bought this tractor and do not know the history.
Allan in NE
11-19-2005 14:53:52
 Re: Clutch adjustment in reply to Clutch problems, 11-19-2005 11:33:01
Clutch,
Hughs got it. Both clutches have to be adjusted. Sounds like one of 'em is draggin'.
Like he says, they have to be exact to the letter.
Allan
Hugh MacKay
11-19-2005 13:31:57
Does this Farmall 400 have TA either working or non-working TA. If so you must adjust both clutch and TA in sequence even though TA may not be working. Get a manual and adjust by the book and precisely to the letter. Close does not count even a little bit with these.
