Super C throttle adj.?
Andrew Z
11-19-2005 15:38:36
Well I got the o'l Super C all together afeter some issues with the fast hitch that was solved here. Anyway When i had the tractor striped down to paint it I replaced the bearing in the governor and the spring. The tractor runs great and the governor does respond to load. Yet I seem to have move the throttle quite abit to get a response. Is there anytype of adjustment that can be made to 'take the play out?? Thanks for the help Andrew
gene bender
11-20-2005 04:33:04
 Re: Super C throttle adj.? in reply to Andrew Z, 11-19-2005 15:38:36
Did you fix the wobble of the input lever when you had it apart? With engine off remove the pin in the clevis going to the carb. Now open the throttle linkage wide open. The pin for the clevis should go back in holding the carb open fully. If not adjust clevis. These two things should end your problem.
Peabody
11-19-2005 20:50:34
I ended up putting a couple or three washers on the front end of the "governor control rod" (what we probably would more commenly call the throttle rod) to tighten up the linkage behind the spring. Worked for me.
CNKS
11-19-2005 17:28:09
You can fiddle with the adjustments on the throttle rod, been too long to remember what I did to mine, I believe I had a similar problem.
