Order Farmall Cub Parts Online
Rich Running Cub!!!
Dog my Cats
11-20-2005 10:18:56
I have a 1952 Cub I am restoring. I have completely rebuilt the engine. My problem is that it runs rich. I have put a kit in the carburetor. I have checked all passages and found them clear. When the tractor runs it puffs black smoke and the plugs become black and fowled in less than two hours. Any suggestions?
Hermit
11-20-2005 17:30:32
 Re: Rich Running Cub!!! in reply to Dog my Cats, 11-20-2005 10:18:56
Your statement that the fuel level is set below specs is interesting. If the spec you're using is the on-engine liquid level check, then setting the fuel level less than the 9/16 inch spec will cause the carb to run rich. If the spec you're using is the float level setting, then setting the float level to less that the 1 13/32 inch spec will cause the carb to run rich. Just an obsevation. Good luck.
El Toro
11-20-2005 11:43:32
You need to check your float level, could be a little high, also shake that float for any gas inside the float. Could cause it to drop allowing too much fuel causing a flooding condition. Hal
Dog my Cats
11-20-2005 11:50:13
 Re: Rich Running Cub!!! in reply to El Toro, 11-20-2005 11:43:32
New float has been installed. The fuel level is set below specs. Thanks
George Willer
11-20-2005 10:30:40
third party image
Did you replace the idle tube? I didn't think so. Often they get broken off and people remove the stub and thread the remainder and put it back in. Bad idea! The tube has a very small orfice in the top that has to be there. Try again and spend the $17.75 for a new idle tube.
George Willer
Dog my Cats
11-20-2005 11:03:59
 Re: Rich Running Cub!!! in reply to George Willer, 11-20-2005 10:30:40
I think the tude is in place, but I am willing to cahnge it out. Where do I get a new one and how do I change it?
