Farmall H hood
Alicefan
11-20-2005 14:41:50
I just pulled an old H out of the woods. The hood was on the ground next to it. I am having a heck of a time getting it back on. The spring loaded catches dont quite line up. Is there a trick to this. Maybe loosen the gas tank or something? Thanks in advance, Dennis
Dave in CT
11-21-2005 06:01:21
 Re: Farmall H hood in reply to Alicefan, 11-20-2005 14:41:50
I'm not sure the hood on my H is original but I have the same problem. The edges line up pretty well with the front cowl and the gas tank. I think making that tool described in the other post would be the fastest solution.
Janicholson
11-20-2005 14:50:16
The hood and brackets are pretty non-specific in location. If the hood is not bent, and the edges seem to line up in the metal of the tank and front cowl, pulling down on them with a hook made from 1/4 inch rod will help. They aren't designed to be accurate, just functional.
JimN
