Re: Super C--How to check engine oil level?
El Toro
11-20-2005 14:52:45
You need to turn the handle on the petcocks 90 degrees to open them. Give it time to drip a little, oil may be a little thick when it's cold.
The oil level should at least be at the lower
petcock. I would add enough so it drips from the upper one if it's low. Hal
