Why have a clutch brake?
Loren in Iowa
11-20-2005 17:40:31
I'm trying to diagnose some problems with the multi disc clutch on our 1925 McCormick Deering 15-30. Why does it have a clutch brake? Our 1927 Farmall Regular has a multi disc clutch, but does not have a clutch brake, and it works fine.
Kevin LA-CA
11-20-2005 19:04:54
 Re: Why have a clutch brake? in reply to Loren in Iowa, 11-20-2005 17:40:31
I don't know the answer, but my '27 Regular, with multi disk clutch has the clutch brake. I don't recall how it was connected.
What is your 15-30's problem?
kevin
Loren in Iowa
11-20-2005 19:40:11
 Re: Why have a clutch brake? in reply to Kevin LA-CA, 11-20-2005 19:04:54
The clutch seems to be sticking. Once I idle the engine way down, and grind it into gear, it will shift OK, if I lock the brake and slip the clutch, to "shine up the discs". But the next time I start it up, I have to go through the whole process, again. The clutch plates are rusty, pitted, and in bad shape, but I don't know where to get new ones. I installed a NOS clutch brake, but it is old and hard. The belt pulley seems to turn, slowly, all the time, but I don't know if that is related to this problem, or something else. Any advice would be appreciated.
old
11-20-2005 20:49:57
 Re: Why have a clutch brake? in reply to Loren in Iowa, 11-20-2005 19:40:11
The clutch sticking like that is common with old tractors. Rust locks thing up fast and easy and unless you either block the clutch down or find a new clutch you will probably have to live with it. As far as what a clutch brake is for I can only say what they do in big trucks. The reason for them is to slow or stop the tranny gears so it you can shift gears a little more easyly.
Kevin LA-CA
11-21-2005 05:24:49
 Re: Why have a clutch brake? in reply to old, 11-20-2005 20:49:57
On my regular, there was rust between the clutch linings and the backing disks. This made the clutch too thick overall - and thickness varied from location to location. I carefully drilled out the rivets, removed the linings. Removed all rust from backing disk and linings. After reassembly it worked well.
Belt pulley spins from heavy grease - I think there is a throw-out lever behind gear shift (10-20 anyway). But does indicate that the clutch is still driving the transmission.
kevin
