Spinout Wheels on a Farmall 350
DannyH2
11-21-2005 07:42:33
You do you get the rims off? I loosened the 1 5/8" nuts but they don't slide back to allow removal of the rim. I've even driven the tractor back and forth and they still won't give. I'm afraid to start beating on the casting of the wheel but I have my doubts as to what that would accomplish anyway.
Dellbertt
11-21-2005 16:19:21
 Re: Spinout Wheels on a Farmall 350 in reply to DannyH2, 11-21-2005 07:42:33
I would start with PB Blaster! Which in my opinion is the best rust breaker.
DWV
11-21-2005 15:58:50
The adjusters are probaly stuck in the cast wheels,they are supposed to go in enough to get rim off after nuts are loosened.
Janicholson
11-21-2005 17:05:52
 Re: Spinout Wheels on a Farmall 350 in reply to DWV, 11-21-2005 15:58:50
Put some weight on it as you work to loosen them up.
tighten the jamb nuts until there is 1/16" clearance then (with PB on the shanks) drive forward and back slowly 20' or so. Just an idea, not to be over done.
JimN
