binderpower856
11-22-2005 13:47:28
Re: 560 gas won't hit on all 6 in reply to Farmall Daddy, 11-21-2005 15:55:02
I had a similar problem with my 560G this summer at a tractor show. I was plowing in the show patch and under a load, it would cut out, spit, sputter, etc. I just knew it had to be a timing problem. First thing I did check, however, was the sediment bowl. It was clean, so I moved on to checking plugs, wires, cap, etc. Finally I turned around and went back to that sediment bowl. Took it down, cleaned out what little was in it, and before putting the bowl back on, I opened the valve to check fuel flow, and bingo, there was the problem... The orifice in the tank had gotten plugged with something, and was restricting fuel. I blew it out with an air compressor (be sure to remove the filler cap before doing that). Made it run like a top again.... Sure did sound like an ignition problem though.... That may not have a thing to do with what is happening with yours, but it's something you might check... Especially when it is only missing when fuel flow needs to be the greatest...
