will a wide front end fit......
john-wiz-
11-22-2005 11:57:13
Would a wide IH front end off a M fit a H tractor????
Steven@AZ
11-22-2005 12:08:18
 Re: will a wide front end fit...... in reply to john-wiz-, 11-22-2005 11:57:13
Short answer, yes.
You will need the steering arm for the H and also the set-back steel plate for the H.
Both the steering arm and set-back steel plate are larger and wider for the M.
If you don't mind the front end sticking out farther in front (longer wheelbase) you don't need to bother with the set-back plate.
caseyc
11-22-2005 12:05:21
sure will.....
casey
