686 fuel in exhaust
Mapleridge
11-22-2005 17:20:39
My 686 with a d312 deisel has some unburned fuel coming out the exhaust. It runs fine with no indication of skipping. I think the injectors and pump are all original. I need help with ideas on how to diagnose what is wrong. Thanks
Jimmy King
11-23-2005 05:22:46
 Re: 686 fuel in exhaust in reply to Mapleridge, 11-22-2005 17:20:39
Put it under a load for 7 or 8 hrs and it will dry up.
Aces
11-22-2005 19:09:14
Mapleride That is not all fuel some of it is oil. do to the oil you use, so recheck the oil spec's to make sure have the right oil, I would say not. With the right if you do as Allan said and get dried up it should stay dry.
Allan in NE
11-22-2005 17:24:35
Maple,
That is completely normal on these diesels.
Wrap 'er up and put her to work. Make her pull fer a livin' and that wetstackin' will disappear.
Allan
