Identification
Fred Frank
11-22-2005 17:26:57
Hi,I have a int tractor, the numbers on the engine plate are 3712 on top and under that J-W, there is c- 135 on the right side of engine stamped in the block, the tractor is yellow but is red under, the grill says Industrial, it has a int 2000 loader on it, has a four cyl gas engine,I would like to find out the year and model numbers so I can order some manuals, and get parts,previous owner has no Idea what it is,any help would be greatly appreciated, thanks fred
old
11-22-2005 18:00:54
 Re: Identification in reply to Fred Frank, 11-22-2005 17:26:57
From what I could find in a catalog it could be one of 3 tractors maybe more. A 330, 340, or 404. Other then that I can't say. Also if it is one of them you need I-T manual IH-201 either way that manual will probably cover that tractor.
Stan(VA).
11-22-2005 17:55:49
The C135 was in the 330/340 and 404. I know they made an industrial version of the 404 as the 2404. The 330/340 Utilities probably just said International rather than industrial?
The 330/340 would have a 5 spd tranny with optional Torque Amplifier and optional IPTO; where the 404 would have a 4 spd tranny with optional High/Low range or a direction reverser, and a std PTO. Depending on model, years would be late 50's to early/mid 60's. I would look on the torque tube (or clutch housing) for a tin serial number plate.
Stan(VA).
fred frank
11-23-2005 16:59:33
 Re: Identification in reply to Stan(VA)., 11-22-2005 17:55:49
thanks for the help, yes this tractor has a lever for reverse or forward, it does not have a pto shaft out the back.It has a small backhoe on it, all the Id plates are missing from this machine, thanks fred
