C-153 engine compression ratios?
flem
11-23-2005 17:17:23
questions on the C-153 engine from 504, 2504, 444, 2444 and various combines. does anyone know the compression ratios between the various c-153 cylinder heads IE: LP vs. gas
I have found that the regular gas engine was 7.7:1 does anyone know what the LP versions were looking for alittle more power.
Mike S 806/H
11-23-2005 23:07:30
 Re: C-153 engine compression ratios? in reply to flem, 11-23-2005 17:17:23
I have a head from a C-153LP , engine was in a fork truck,
flem
12-02-2005 08:16:42
 Re: C-153 engine compression ratios? in reply to Mike S 806/H, 11-23-2005 23:07:30
Mike, do you still have that LP head?
Hermit
11-23-2005 19:16:42
Looking at the engine specs, I didn't find the compression ratios but it does show the compression pressures. The gas has a compression of 180 psi and the LP has a compression of 185 psi. So there is a slight increase in compression ratio but not by much. Hard to say how much of a power increase you would have.
