Blocks interchange?
BigManOnCub
11-24-2005 09:27:23
Hello,
I'd like to find out if a 251069 block is inter-changable with a 6342 DH block? If not what will?
Thanks
Jim Becker
11-24-2005 10:09:41
 Re: Blocks interchange? in reply to BigManOnCub, 11-24-2005 09:27:23
It would help if you mentioned what tractor model the donor block is from and what you want to put it in. It would save anyone responding the trouble of chasing part numbers.
Looks like you are asking about the early Super A block, 251069R1 and the A block. They are partly interchangable. The important difference is that the R number has provision for a hydraulic pump while the D number does not. So you can use the R number in an A but not the D number in a Super A.
Jim Becker
11-24-2005 10:17:08
 Re: Blocks interchange? in reply to Jim Becker, 11-24-2005 10:09:41
OK, I saw your other post half way down the page. Installing into an A, you should be good to go with 251069R1. The comments Hugh and Stan made on the other post pretty well cover it.
