W-6 Woe,s,
11-25-2005 06:17:13
this w-6 I have has alot of little thing,s that arte on it, sombody welded little angles tab,s on the front axle to heep it from moving to much up and down,then they cut a hole out of the hood for an alternator,but it too far out. put car type mud tires on front,it has M type front wheel,s instead of W-6 type,It has full hydralic,s on it but somebody welded two pipes onto the hydro tank on the left side,for i guess better access to fill it look,s like crap, to top this off,a person put power steering on it and all the hoses droop froom left side of engine,and made a bracket for the P/S pump,and put it in front of governer on left side,and then welded tab,s onto the right tie rod wit the hydro cylinder connected to that then running back along the right side of tractor,also with tab,s on the radius rod,s underneath, Totally Grosse!
