560 govenor troubles
Gamitch
11-25-2005 09:14:24
Pop"s 560 gas won"t run right govenor-wise. It"s either on or off, not much control in between. I"ve checked it over and everything looks okay. I thought maybe the linkage was gunked up so I WD40"d that a bunch but no improvement. The "innards" and spring look good. Any experience with the problem?
Thanks,
Gary
the tractor vet
11-25-2005 09:34:56
 Re: 560 govenor troubles in reply to Gamitch, 11-25-2005 09:14:24
With out looking at it I am going to guess that the thrust bearing is the problem . Pull it off and take it apart and see what is woren and replace said part or parts. And then readjust as per spec.
Gamitch
11-25-2005 12:41:52
 Re: 560 govenor troubles in reply to the tractor vet, 11-25-2005 09:34:56
Thanks man!
